1 - 10 of 10 Posts
I'm updating my stock fuel system. So far I have 255lph in tank pump, kirban fuel pressure gage, and all the minor stuff for the tank. Still need fuel pressure reg. I want to run braided hoses but not sure if its really needed. But if so What size hose to buy?And what psi should the stock 19lb injectors be ran at.
I wouldn't worry about it. At your power level (since your still able to use stock injectors) the added size of a 6an or 8an setup won't help you any performance wise unless your lines are rusted through or you feel like throwing money into it
I got a FRPP boss block that I plan on building to replace the stock motor. Just want to go ahead and do the fuel system ahead of time since I already have the tank dropped.
If your power is low enough that you can get away with 19 lb/hr injectors, upgrading your hoses is going to be just for show - there's no need for bigger fuel lines when the injectors are your real bottleneck.
You still don't need to upgrade the fuel lines, hell the stock injector rails are good up to 400 or 500hp I forget now. I'd put the money else where if it were me but if you plan on sumping the tank and **** then you might as well convert to braided
1 - 10 of 10 Posts
