1 - 8 of 8 Posts
So I got a MGW shifter for v-day and I got the stop kit with it, it says the the stop kit could damage the transmission b/c the transmission has internal stops, what is this and should I just not put these in?
Its not needed, nor recomended by MGW, the 3650 has its own internal stops.
Also, setting the shifter is up to you, I have mine @ 2 turns since I shift a lot and its the smoothest for me, 07 procharger has his @ 7 turns IIRC.
Intalling the shifter should take you about 2 hours, and don't worry if you don't like your starting setting,you can change the setting in about 15-20 minutes including lifting the car and then putting everything away you used away.
Doc
Yea I knew that much for the 3650 but what's the whole "turns" thing apply to then?
I know your Short throws hook up differently
1 - 8 of 8 Posts
