1 - 6 of 6 Posts
The Boss is in
you can do it on either lift. but use the drive on lift if you can. All you do is lift it up and weld them on
I used a two post lift for mine and they turned out great
Discussion Starter · #3 · (Edited)
does the weight have to be on the tires or anything because the alignment lift is drive on but space to weld them were the need to be is limited the post lift the lets the suspension hang but i have to lift the car by the front subframe & torque boxs
also the post lifts im talkin about are above ground lifts with 4 lifting points.
The Boss is in
Lift the car by the very front of the subframes and the rear of the torque boxes. thats what I did exactly
I took a few pics ill see if I can find them
Yes, lift it by the frame and take extra time to make sure it is level before you start welding.
1 - 6 of 6 Posts
