1 - 6 of 6 Posts
Well, I blew 2 piston in my motor:mad: Anyway, I have access to a 98 Mark VIII 68k mile shortblock for a great price!! My plans are to use the Mark VIII shortblock with a set of SHM ported SVO heads. My compression will be 10.1 with the Mark VIII pistons and the ported SVO heads. I also plan on sending my SVO blower out to Stiegemeier for their stage 6 porting! I also will be using Comp xe274 cams as well. So to sum it up the combo will consist of:
10.1 compression Mark VIII shortblock
Stiegemeier Stage 6 ported SVO blower (6-8psi)
Comp xe274 cams
75mm t.b
JLT cai
42lb injectors
90mm LMAF
MSD coil packs
4R70W w/Transgo shift kit
PI 3500 stall converter
3.73 gears
FRPP shorty headers, Off Road H-pipe, Magnaflow Catback
How much horsepower do you think this setup is capable of? Also, would this be enough to run in the 11's?
Rollin' 18/ pushin' 2
I think you should add the meth kit man, just speaking from personal experience.
As described I think you will be close to 400 rear wheel. I made 375 rear wheel with 9:1 compression at 6 lbs on a very similar setup. :naughty:
With meth, good tuning and the higher compression I would think you could see around 425
1 - 6 of 6 Posts
