1 - 11 of 11 Posts
as of now i have a pretty good setup and get real good power but i want alot more :D what would be a better investment for my setup in you guys opinion supercharger or nitrous? and i have a 190lph fuel pump whats the maximum amount of boost i can plan on pushing without changing fuel pumps? also how much power could i expect with a charger? to around 6-8psi
what u have 2 spend ?because if you got the money go supercharger,but if not, nitrous is the best bang for the buck.
i say blower but then youll need to upgrade fuel system.....probly with 8 psi id say 36-42 lb injectors....255 lph fuel pump and fuel pressure regulator.....and a custom tune to make everything run well......
basically the nitrous is gona be a lot cheaper but the supercharger is power all the time instead of just when the nitrous is on and u dont have to refill a supercharger ....lol
i have 24lbs maf sensor afpr and 190lph
24 lbs injectors definitely will be insufficient for a blower......and i would be a new pump too honestly......u might could be by with it though
nitrious if your just going to do track
supercharger if you want to have all around
Both??
not if you were running 2 psi and a 50 shot
1 - 11 of 11 Posts
