1 - 18 of 18 Posts
Safud: MM's Resident Hadji
You will need a different lower intake, bigger injectors, fuel pump. etc.
:rolleyes:
To the OP...Don't get that one, it WONT work on your car. If you want the Eaton get the style thats on the 03/04 cobra's. Those usually go for around $300 over on svtperformance :yes
Ive seen these on v6 models before though. And how do you find a supercharger for 300 bucks?
You haven't seen THAT supercharger on v6 mustangs....There is different versions of the M112. You need the M112 that comes stock on 03/04 cobras/lightnings
And you find a supercharger for 300 on svtp when all those guys have the s/c stock and want to get rid of them to upgrade to a bigger one ;)
so this one would work? I did more looking and found what you might be talking about.
03-04 Mustang Cobra EATON M112 supercharger 4.6 dohc:eBay Motors (item 280415063123 end time Nov-01-09 14:27:55 PST)
These are phenomenal prices. Would this one install right on top of the engine? Would i have to get an aftermarket hood?
You are going to have to go through a LOT of work man. It doesn't just "bolt up" as it needs custom pieces and you will need a new hood (unless you want to cut yours and have it sticking out of the hood)
Here is the parts list
2003-2004 Cobra M112 Supercharger
2003-2004 Cobra plenum
2003-2004 Cobra throttle body
2003-2004 Cobra 39lb injectors Cobra 90MM MAF With MAF Sensor
2003-2004 Cobra boost bypass
2003-2004 Cobra supercharger pulley
2003-2004 Cobra throttle and cruise control bracket
2003-2004 Cobra air intake tube
2003-2004 Cobra TPS sensor
2003-2004 Cobra M112 supercharger gasket- RTV sealant works best
2003-2004 Cobra plenum gasket
2003-2004 Cobra throttle body gasket
2003-2004 Cobra fuel injector O-rings
1999-2004 Mustang V6 upper intake gasket
M112 intake adaptor
PCV delete
2003-2004 EGR delete
IAT Sensor and Wiring
CNC MAF flange
310lph fuel pump (98-04 cars)
NGK TR7IX spark plugs
Gatorback belt #4061182 or 6PK3002(metric part number)
Air Filter With Filter Box
M112 EGR delete
12 bolts for adapter to V6 lower intake
12 washers for intake bolts
10 bolts for M112 to adapter
4 bolts for the plenum to the M112
4 bolts for the throttle body to the plenum
4 bolts for the MAF to CNC flange
2 bolts for IAC delete to plenum
2 bolts for IAC relocation
2 bolts for IAT relocation to M112
2 bolts for Cobra throttle cable bracket
2 clamps for air filter
Custom made pieces:
Tuning EGR delete
Coli pack bracket
Radiator hose
IAC relocation
IAC block off plate
Idler pulley setup
IAT relocation plate
IAT gasket
Shave off intercooler lip
Longer wiring for IAT relocation
Discussion Starter · #12 ·
Wow....How hard would it to get those parts individually? If i bought the one im looking at, i would get the bypass, and the throttle body and what he called an elbow?
Also, could i cut my hood then cover it up with an aftermarket hood scoop from AM?
The elbow is actually called the "Plenum"
And I got all the parts for less than $1400. But thats because I did all the custom work myself
And no...A hoodscoop wont cover it. It'll cover most of it, but the pulley will still be visible
Sorry to jack the thread... but does anyone know what the power gains are around after install of the supercharger?
Typical results are around 240 to the wheels
Will the supercharger fit with my cold air intake?
No...You will need a new one. You can use the portion after the MAF though as that is no different
1 - 18 of 18 Posts
