1 - 10 of 10 Posts
· Registered
Ok, I am hoping to build a car that is street strip, and decent at cornering. I am jc what suspension setup would work well on the drag strip, but still be decent when it comes to cornering. I know about lower contorl arms, shocks, springs, are there any other things that would be good for both? Is there a way to make a car that is good at drag and cornering? thanks.
i know that this is also off topic, but if i had an 02 5spd with tlok, 3.73s, xcal 3,udp, cai, windstar upper, p&p lower, and a cam. Along with a decent suspension what could i expect in the 1/4 mile with some seat time?
· Registered
I have read that it is recommended to use components from the same manufacturer instead of mix and match. BUT, I've only read about it. I myself am just getting ready to start replacing OEM components. I personally have decided on UPR. Good luck on your quest.
· Registered
i have been looking at steeda, i may look at upr also. and thanks. you too good luck.
One more ? to add, is there any front suspension that would allow me to adjust the front ride height, and not like air ride or anything, becasue in the winter i do not want the front to sit so low.
· Registered
alright, well what would be the best bet for shocks, and springs, or maybe coilovers if i want adjustability.
· Banned
Eibach Pro kit + Tokico Blues are a good choice. But you cant really have adjustable height. The only thing adjustable on adjustable shocks/struts are the stiffness.
· Registered
ok, well that is the only problem, unless i get a car for the winter. I know that coilovers i believe you can adjust the height on. What all do you need for coilovers?
· Registered
ok well it seems the way to go is eibach with adjustable shocks. how about the lower control arms do they help a lot?
1 - 10 of 10 Posts
