What do you guys know about them? i know there are 2 different ones. there is a pump that is made to run by itself and then there is a pump that is made to run in a dual pump setup. what is the lph of both setups? what kinda power would a single setup with a bap be good to and what kinda power would the dual setup with a bap be good to? how far will 42 lb injectors take me? the car makes 471rwhp through an auto at 10lbs intercooled with a 2.9 pulley. looking at bumping it up to 12-14lbs and going to an 8 rib setup with an overdrive crank pulley,adding a 100shot, shooting for about 600rwhp with same or more torque, hoping the nitrous will up the torque because it has a huge stall and im wantin the nitrous to make up for that.
