1 - 14 of 14 Posts
I did it to my 91. You need a dizzy, the head.and intake. Use the newer throttle body, and you have to do some pinning to plug the dizzy in. its not a bad job, i figured it out myself in high school with some wiring diagrams.
Distributor, easier to type dizzy (thats what alot of my friends call it) Sorry for the confusion!
what would the advantage be?
Might be easier to modify the ignition system to maintain DIS, rather than converting to dist/TFI?
The big advantage you get from this conversion, which does not require a computer change, is the ease of timing advance change. Without a tuner it is unchangable with the 8 plug. The 4 plug intake and head are better for performance (i think) than the 8.
Damn sorry I just re read last
Post again sorry for the computer ? Lol so all I need to get is upper and lower intake head and dizzy correct
All of the 2.3 heads from our engine family will fit your engine block, including the 2.5L Ranger. Other than the Esslinger SVO head RACE ENGINEERING - Cylinder Head - 2300 - 2500 - 2700 - 2850 - Race Engineering, Inc and the Race engineering head, the castings I like the most are the last single plug castings, available on Mustangs, 87'-90. Ironically, they don't flow that much in stock form, but a few hours with a rotary file, can make a huge difference with them.
Here's what the un-ported airflow looks like on the 87'-90 casting I recently tested.
Lift in Inches
0.100
0.200
0.300
0.400
0.500
Intake CFM
56
105
137
142
149
Exhaust CFM
41
82
114
131
140
You can use a head from a ranger up to 2001. After that the changed engines. There is not a diagram that can be used specifically for this conversion. I do however have the diagrams, and pin locations to do it, i have already went through this somewhere in these forums, if you look around its there. Also, any head from 88-on ranger and 91-on mustang will not be compatible with a distributor. they are all 8 plug and the intakes et in the way of the distributor.
I am needing a 4 plug engine with distributor yet all i am finding is newer with coil packs. How hard would it be to swap over to 4 plug distributor on a 8 plug 2.3?
1 - 14 of 14 Posts
