1 - 2 of 2 Posts
this might be a dumb question but im getting ready to have my rear end switched to 31 spline with 3 73 gears etc i have the axles, gears, differential but do i need to change the spool as well?
Did you have a spool in before? (mini spool or full spool?) If you did I’m guessing it was not 31 spline due to you switching everything over to 31 spline. So to answer your question, yes you need to get 31 spline for whatever your running (Spool/Locker/Limited Slip etc…).
1 - 2 of 2 Posts
