1 - 2 of 2 Posts
Hey all,
Yet another question from the mustang noob here.. I bought my 86 GT a lil over a week ago, One of the many issues with the drivetrain/powertrain of the car is that it is stuck in 4th gear.. We were able to get it out of gear as it was going down the trailer(Rear end down, Front end upward for those concerned with fluid locations in tranny) then when we hit it into 4th gear, it got stuck. (This happened when we were on falt ground btw) Any body have this problem? Is it common? How fixable is it?
I would 1st check that the clutch is in fact ingaging all the way when you push the pedal in, if it is, try and rock the car forward and backwards then try again, if not, jack up the front and see if it helps, most likely the trans has to come out and be checked out anyways. what happens when the engine is running?
1 - 2 of 2 Posts
