1 - 19 of 19 Posts
Potato
I need a bezel that fits a kindle fire HD. Can anyone help out? I have seen double din/ and I have seen other droid base tablets. I am wanting to permanently install the Kindle Fire. I have a base model radio.. and its weak. Any suggestions before I have to buy an aftermarket and start cutting it up my self (and it end up ugly)?
There is one guy I met at sema this year that had an iPad in his dash and it looked factory.
Let me see if I can contact him and see what he did. Heck I like the idea too. I might want to do it in my car.
Since the front panel is a module that communicates with both the radio and climate control, you need to start with an aftermarket dash kit for a new radio. Any good sereo shop worth thier salt will be able to modify this piece to mount whatever tablet you want.
Aside from the required plastic welding, filling, paint/covering you will also need to come up with an interface for the tablet to the car and some sort of amplifier to power the speakers.
Potato
Can I tap into the headphone jack that's supplied in the center console? I'm a DIYer but this might need to go to a professional.
Potato
exactly what I want, just with a fire kindle.
To tap into the headphone jack that is there from the factory, you would still need the stock stereo installed to power the system.
5.Slow Driver
What people are doing is.... The factory radio is just a box behind the dash plate. They are mounting the tablets and plugging them in with a USB cord to the factory radio with sync... And using the tablet as all of the functions with the factory radio basically just being the amplifier from what I understood. Then making the faceplate to fit the tablet.
Potato
Discussion Starter #10
****. I knew I should of ordered the tech pack too. Think I could use an aftermarket Bluetooth set up?
Potato
Discussion Starter #12
Whoa, where did that mount come from...
Potato
Discussion Starter #14
Great no Kindfire HD version...
Potato
Discussion Starter #16
Youre giving me bad ideas..
Oh no, your doing this with me, Our stock radios..... Don't have bad ass gauges in them....
or porn.
5.Slow Driver
Doug
heres mine I did a couple weeks back:
Works like a charm!!!
I have since replaced the CF trim piece to make it a little cleaner install.
1 - 19 of 19 Posts
