So I have been throwing a CE code of lean for a while now, but its intermittent. It will come on for up to a day or so, then go off for a week. I can't justify being hard on my engine or anything prior to either.
My guess is that either one of my O2 sensors is bad or clogged?
Thoughts?
Also
When I pull my e-brake the first time, it will pop and brake loose, allowing my car to roll when I am not in gear. But if I pull it, let it back down, and pull it again, it locks just fine and has never released if I followed that method. Never seen this before, and have no idea what the hell is going on.
Thoughts?
and lastly;
When I get my car over 3,000 rpm or so my battery will lose power consistently with my increase in RPM. I assumed my alt was going bad, but when I went to get it tested I was told it was just fine and had no problems.
Maybe its a bad ground or something? But wouldn't that effect it at all RPM's?
Thoughts?
One or two of the questions I have asked in the past I believe but it was done through a threadjack and I got weak answers, and wasn't even sure if they were directed to me or not.
Thoughts?
Also
Thoughts?
and lastly;
Thoughts?
