1 - 3 of 3 Posts
Been thinking about a BUDGET Teksid build (Teksid block) with ported PI SOHC heads. Has anyone here had any experiences (good, bad, or indifferent) with this type of setup? Looking to get close to 400 hp n/a, is that within the realm of possibility or will I need a power adder (i.e forced induction)?
Also would I need a Cobra intake or what choices do I have for the upper/lower intake?
With 2v heads you won’t get anywhere near that na. And the only intakes I would use on a 2v are stock and the edelbrock.
Sent from my iPhone using Tapatalk
if you are going to use 2v heads you have to use a 2v intake manifold. you most likely wont make more power with just a teksid block. you will save some weight tho. as far as intakes for the 2vs their are a few different options.
1 - 3 of 3 Posts
