1 - 3 of 3 Posts
Hi all I'm looking to replace my sensor and switch as I took them off and got them confused as to which is which since my gauge stopped working I am hoping someone can help me out
I believe the sensor on the right side of the coolant crossover pipe is the Temp switch but want to make sure. I believe part number is TU241 but hopefully someone can correct me.
Here is a image with the sensor's I'm talking about
If you also know of the temp sensor part number I'd greatly appreciate that too.
Thanks,
Josh
The temp sensor on the left controls the gauge
The temp sensor on the right is what the pcm uses for fuel mapping and to run the fans
Thanks boss got it running. Pepboys tried to give me the same sensor for both sides saying they didn't have the same range. Ended up having to go to Auto zone for the switch. I had the right part number for them. Now I need to figure out why my fan isn't kicking on. Could be my relay under front passenger fender.
1 - 3 of 3 Posts
