1 - 1 of 1 Posts
Have a few questions about throwing together a 4.6 until i can get my 5.4 build finished up. I found a 4.6 that needs rings for $100. My thoughts are to throw my trick flow heads and MHS cams on it and run it until mid summer.
My biggest thing is i want to bump the compression a little bit to make the cam a little more worthwhile in the 4.6. What would be a safe compression ratio to run with 93 octane?
Also if i buy after market pistons will i need to have them notched? MY cams a is a stage 3.5 TFS N/A cam. I can post the specs when i find my cam cards.
1 - 1 of 1 Posts
