1 - 8 of 8 Posts
Zip's half naked helper
This thread is for the ten entrants in this month's contest to showoff their rides. any other small talk will be deleted, so please save it for the voting thread. I'll have that thread up Saturday. Good luck to all!
Here is my 1996 Cobra that I bought on 11/17/12 after selling my first car (98 v6). Some mods that were done to the car before I owned it: 3.73 gears, Magnaflow Tru-x Catted X pipe, Mac Catback, S281 Wing and 04 Cobra Wheels.
Now here is the full list of mods:
WISH LIST/TO DO:
  • SHAVE & REPAINT ENGINE BAY
  • WIRE TUCK ENGINE BAY
  • AEROCATCH HOOD LATCH/PINS
  • ENGINE REPLACEMENT EITHER: SUPERCHARGERED COBRA MOTOR OR COYOTE SWAP
  • TRANSMISSION REPLACEMENT: T56
  • IRS BUSHINGS, GEARS AND POWDERCOAT
  • DOUBLE DIN CONVERSION W/ TOUCHSCREEN RADIO
  • PAINT TO MATCH WIPER COWL
  • RETROFIT HEADLIGHTS
EXTERIOR:
  • CUSTOM PAINTED 12 INCH 'SPIRITED GREEN METALLIC' STRIPES
  • S281 SPOILER
  • FOLDING 04 COBRA MIRRORS
  • CUSTOM SMOKED HEADLIGHTS & TAILLIGHTS
  • SEQUENTIAL TAILLIGHT HARNESS
  • 3K COOL WHITE HID HEADLIGHT & FOGLIGHTS
  • CUSTOM HAND PAINTED COBRA EMBLEMS
  • 20% WINDOW TINT W/ FRONT BANNER
INTERIOR:
  • 04 COBRA CONSOLE PAINTED BLACK
  • AUTOMETER GAUGE POD W/ WIDEBAND & COOLANT TEMP
  • REDLINE GOODS LEATHER SHIFT & EBRAKE BOOT
  • GREEN FOOTWELL & CUP HOLDER LEDS
  • BULLITT PEDAL COVERS
ENGINE:
  • BBK CERAMIC LONG TUBE HEADERS
  • BBK OFF-ROAD X PIPE
  • POWDERCOATED GREEN VALVE COVERS
  • POWDERCOATED UPPER INTAKE
  • POWDERCOATED COP COVERS
  • EGR & SAI DELETE
  • COP CONVERSION
  • CUSTOM HAND PAINTED INTAKE PLAQUE
  • ON3 PERFORMANCE BRAIDED COOLANT HOSES
  • JLT RAM AIR INTAKE
DRIVETRAIN:
  • STOCK T45 WITH MGW SHIFTER
  • RAM HDX CLUTCH
  • STEEDA CLUTCH QUADRANT
  • MM FIREWALL ADJUSTER
  • 01 IRS W/ STOCK GEARS
SUSPENSION:
  • H&R RACE SPRINGS
  • 04 BILSTEIN TAKEOFFS
  • MM SUBFRAME CONNECTORS
  • POWDERCOATED STEEDA FRONT SWAY BAR
WHEELS & TIRES:
  • 18X9 BLACK SALEENS
  • 245/35/18 NITTO EXTREME PERFORMANCE N555
  • POWDERCOATED CALIPERS W/ HAND PAINTED LETTERING
  • BLACK ZINC COATED DIMPLE & SLOTTED ROTORS
  • CERAMIC BRAKE PADS
Canon Gang
Here is my 2001 V6 Coupe. AKA Whitey. Mom bought the car brand new in August of 2001, and can be seen here as of day 1 of ownership (And little Swift mounted on his motorcycle)
The car as of now is as described below
Exterior
-Urekem "Super Bright White" urethane paint
-18x9/10 staggered polished Saleen replicas (255/35/18, 285/35/18)
-Custom fender emblems
-Shaved trunk key hole
-SN95 sail panels with matching glass
-Shaved Ford oval
-GT hood scoop
-GT foglights
-Shaved GT rear bumper cover
-Aerocatch flush mount hood pins
Interior
-Jegs GS-1 Sport seats
-UPR rock crusher shift handle
-Fire extinguisher safety mod lol
Suspension
-Bilstein HD struts
-Maximum Motorsports coilovers
-GT rear sway bar
-SR Performance CC plates
-Steeda Bumpsteer kit
-Brakemotive drilled/slotted rotors with ceramic pads
-FLSFC's
-03 Cobra A-arms and bushings
Engine
-Low mile 2004 3.9L drivetrain
-SR Performance CAI
-EGR delete
-O/R H pipe with Flowmaster 40's and Pypes 3" tips
*Side skirts not pictured, but will be installed shortly lol*
1992 Mustang GT Super Clean Virginia Car. 90k.
Stock 302, Trickflow Track Heat intake(in progress), Crane 1.7 Roller Rockers(in progress), BBK 65 mm T Body, BBK 65 mm EGR spacer, BBK MAF, BBK fender well CAI, MSD Cap/Ford Racing wires, pulleys, stainless shorty headers, Mishimoto oil cooler, AC delete, smog removed.
BBK catless h pipe, Flowmaster American Thunder Cat back, 2.5 stock exit tailpipes.
T5 5 speed, Hurst short throw shifter, Hurst line lock.
8.8 read end with 3.55 ring and pinion, Moser axles, ARP wheel studs, Perfect Launch girdled cover, drive shaft loop. UPR chrome molly upper and lower control arms, Wild Rides Battle Boxes.
Stock clean interior.
15x4 front runners, 15x8 rears with 275/65 15 Mickey Thompson ET Streets.
Slowly building it into a reliable fun street strip car.
Here is my fox, goal for this car is a fun, reliable, can turn left and right, can go straight quickly as well, and have wifey ride comfortably in a long cruise.
1992 Mustang LX Coupe:
V8 Drivetrain swap:
306CI motor, Stock HCI (everything fresh under hood, new pulleys, water pump, valve covers painted, engine bay painted, new wires, coil, etc.)
New rebuild T5
8.8" rear end installed with 3.73 gears
Intake/Exhaust:
Hooker shorty headers
BBK offroad H-pipe
Flowmasters
BBK inner fender CAI
Suspension:
Front:
MaximumMotorsports C/C plates
MaximumMotorsports coilover kit
Hypercoil 12" x 250# springs
Tokico D-spec struts
MaximumMotorsports control arms
H&R 3/16" spacer
Rear:
MaximumMotorsports XD adjustable height rear lower control arms
V8 springs cut coil
UPR spherical axle housing bushings
Wild Rides upper and lower torque boxes
MaximumMotorsports panhard bracket (bar removed for now)
Wheels/tires:
17 x 8 & 17 x 9 Chrome Saleen SC wheels
245/45/17 & 275/40/17 Nitto 555 Extreme tires
Interior:
swapped V8 dash cluster
2003 GT leather seats front and rear. Powered driver seat
MillaMat sound deadener from firewall to tailights
Pioneer 3-1/2" dash, 6-1/2" door, and 6x8 rear trunk lid speakers
JVC head unit
Rockford Fosgate amp
Kicker Solo-Baric 8" sub with handmade box
Exterior:
2013 Ford Performance White paint
3" cowl hood
shorty antenna
Started as a 4cylinder
Unloading her, fresh 2013 White paint.....
From 4cylinder motor awesomeness...
to the motor of the car gods (5.0 pushrod > all) :shiftyeyes
Everything works as it should inside, no airbag light flashing, heck even the ashtray lid works right =)
Safe to say I couldn't figure out what wheel color I wanted =)
Nice sticker ShelbyDog =)
As she sits now
NarleyCarley's 1992 Coupe Build Thread
missippi roolz
Wow, just saw that I got nominated for this. Thanks for that!
Unfortunately, my car is in pieces right now so I don't have any new pics. Will hopefully be back together and running by the end of the month.
At work so don't really have time to get into the nitty gritty but:
5.0L stroker - 393 STD RWHP, 358 RWTQ
106200 camshafts
Ported/Polished heads
Ported stock intake
Intake Spacer
03 Cobra IRS with Full Tilt Boogie Racing bushing kit and upgraded tie rods
4.10 Gears
Full Maximum Motorsports front suspension setup including coilovers
18x9/18x10 Silver FR500s
Pictures show flat black spoiler but I just recently had it painted so it will look 10x better once the car is back running again.
From past photoshoot:
This is essentially it's current state, hope to have the engine/trans at least back sitting in the car by the end of this week depending on weather and my free time:
Thank you for the nominations and to all of you who consider voting for me!
My name is Dennis, I'm 35 and this is my 1987 Mustang GT. I am the 4th owner and purchased it on February 15, 2013 with just 57,200 miles, totally stock except for a nice custom stereo and dark window tint. One of the rarest color packages offered in '87-'89. Full option delete car - no power anything, no cruise, originally am/fm radio, auto, hard to find factory 3.27 axle ratio and dealer special optioned Ford Motorsport 140 mph speedo. 100% factory original paint, rubber, trim, lights!, interior and mechanical components except for maintenance items.
The original owner was an older woman who worked for Kemp Ford of Thousand Oaks, California. Because she was employed at the dealership and lived close to work this car led a very pampered life with limited miles and a perfect service record. The 2nd and 3rd owners had the car for less than a year each. The 2nd owner did nothing but keep it clean and garaged, only driving it a handful of miles. The 3rd owner did manage to put about 1,200 miles on the odometer as well as a new set of tires, tint, stereo and killer paint detail.
I had decided at the start of 2013 that it was time to move on from my very modified '88 notchback that had served as daily driver for the better part of 14 years. The car had seen a lot of use and a lot of abuse. It also didn't comply (at all) will CA smog and I was getting tired of having to shell out pockets of 100 dollar bills to shady smog shops for a passing inspection.
In February of 2013 I started searching for a replacement Mustang. My search criteria: 1986-1993 LX or GT, low mileage, no hit, all original, no modifications, no convertibles. After a short two day search I came across a Craigslist ad late on a Monday night for this GT. The exact GT I had wanted since 1996 when I was 16 years old, which I fell in love with after buying a Chilton's repair manual with an identical GT on the cover! The only thing is that this color package is so hard to find (Oxford White over Titanium with blue accent stripe) that I never thought I would EVER actually own one in any condition, let alone mint. So hard to find that this car is only the second one I've ever seen in person in my 20 years of 5 Liter Mustang involvement. The first being in 1998, an '89 belonging to a friend of a friend.
The GT was located 2 hours north of me in the city of Santa Barbara, CA. After talking to the seller on Tuesday (kind of an odd guy and fairly frustrating to deal with) it became apparent that hooking up with him to look at the car in person was going to be difficult because he was only available during the week and I was only available on weekends. As luck would have it, one of my best friends, Christian, also lived in Santa Barbara and just a couple of miles from the seller. Christian and I had been wrenching on Mustang's together for 15 years and if I could trust anyone to look at the car for me, it would be him. Christian got together with the seller and reported back that if this GT is what I wanted he couldn't imagine finding a nicer car. I contacted the seller again and told him that I was ready to purchase the car for his asking price of $8,500 and that Christian would be doing the deal on my behalf. That was on Wednesday and the seller demanded cash only and completing the sale by Friday so that he could buy something else. I had the money, the only issue was that Christian didn't have a local bank making cashing a cashiers check or withdrawing a wire transfer impossible in short order. There was just one option. Taking an insanely stupid risk, on Thursday (Valentine's Day!) I stuffed 85 one hundred dollar bills into a UPS Next Day Air envelope and sent it out with the rest of the daily pickup from my work. And, no, I didn't sleep a minute that night!!! Luckilly, everything went okay. Christian got the cash the next morning and called me around noon to tell me he had the car in his possession. Two days later on Sunday morning my wife and I drove up to Santa Barbara and picked it up. It was so nice in-person that I was literally afraid to touch it and the two hour drive home was quite nerve wracking. To this day, as I sit here typing this I still can't believe that I actually own this car! I don't know what else to call it besides fate.
About two months after purchasing the GT another best friend, Matt, came over on a Saturday to assist in a 13 hour marathon installation of the group of modifications I had planned: H&R springs, Koni adjustable struts/shocks, MM camber plates, MM panhard bar, MM stock brake upgrade kit (MM braided hoses and stainless caliper bushings, Hawk HPS pads, heavy duty shoes), Power Slot rotors, ranger/aerostar axles & drums, ARP wheel studs, genuine FMS 17x9" '95 Cobra R wheels with 255/40 tires, Dynomax catback, FRPP aluminum driveshaft, Energy engine/trans mounts, K&N filter, vintage Ford Motorsport 8mm blue plug wires, air silencer removed, base timing to 14 degrees. The following weekend I proudly displayed the freshly set up GT at the annual Fabulous Ford's Forever all-Ford car show.
For two years now the GT has served as my daily driver to and from work, about 20 miles a day. No other modifications are planned. Just the basics for a nice, tasteful cruiser.
Hosted on Fotki
Hosted on Fotki
Hosted on Fotki
Hosted on Fotki
Hosted on Fotki
Hosted on Fotki
Hosted on Fotki
Hosted on Fotki
Hosted on Fotki
Hosted on Fotki
:naughty:
Thanks for nominating me! Here is my 2000 v6, It's my daily driver and I've had it for 4 years, it was my first car and I never plan on selling it. It has 175k miles.
I currently have a complete mark viii 4 valve engine, and transmission, that I will be swapping into it, we are almost done pulling the motor and trans from the mark and then I will add 96-98 cobra intake manifold (which I've already bought), 99-04 gt fuel rails, long tube headers, cold air intake, etc. before putting it in my car.
Current Mod List Includes:
-mach 1 grille delete
-smoked AM headlights
-smoked LED 3rd brake light
-18" staggered solid black fr500 rims
-Sumitomo tires 245s up front 285s in back
-Dual exhaust w/ H-pipe, Thrush mufflers, and 3" chrome tips, no cats
-CAI
-brushed steel radiator cover
-Chin spoiler
-tinted tail lights w/ VHT
-tri-bar side emblems color matched (god)
-Sony xplod radio
-01-04 GT side scoops
-GT rear bumper cover
-Carbon fiber rear "MUSTANG" insert decals
-Black bullitt fuel door
-Roush stage 3 rear spoiler
-Custom black&gold vinyl upholstery
-HID's: 6k in heads (theretrofitsource) and fogs (ddmtuning)
-brake calipers painted purple
-shorty antenna
-H&R Supersport lowering springs
-LMR 2.5" cowl hood
-99-01 cobra bumper with tinted fog lights
-Polished moroso brake reservoir cover
-Some billet interior trim
-Hood struts from AM
This is what it looked like when I first got it:
And here are pictures of what it looks like now!:
Interior Pic (before billet window switches and tri-pony floor mats):
And here's the motor that's going in (after it's cleaned up and some things changed):
1 - 8 of 8 Posts
