Status
Not open for further replies.
1 - 8 of 8 Posts
ENGINE REMOVAL /REPLACEMENT
How To: Remove engine
How To: Mark VIII engine swap
ENGINE MODIFICATION /REPAIR
Forced Induction (FAQs) & Turbo/Supercharger Basics Pt.1
How To: Understand nitrous and effects of installation
How To: Understand supercharger and effects of installation
FI (FAQs) Pt.2
FI (FAQs) Pt.3
FI (FAQs) Pt.4
How To: Build affordable super-charger
How To: Understand beyond bolt-on upgrades
How To: Degree cams
How To: Assemble bare PI heads
How To: Install V-1 T-trim with FMIC
How To: Enable full-throttle cable adjustment
How To: Clean the AIC
How To: Install Airaid intake
How To: Exhaust system upgrade
TRANSMISSION REMOVAL / REPAIR
How To: Replace your clutch
How To: Tailshaft lubrication mod
How To: T-3650~T-56 transmission swap
How To: Auto to manual transmission swap
REAR END REMOVAL / REPAIR
How To: Compare 3:27 vs. 3:73 vs. 4:10 rear-end gears
How To; Installation new rear end gears
How To: Understand fuel use with new gears
How To: IRS to SRA swap
How To: Fuel pump wiring upgrade
How To: Fuel tank filler gasket replacement
SUSPENSION
How To: Official Suspension Guide
How To: Replace struts
How To: Install Coil-overs
How To: Cut Your Stock Springs
How To: Reinforce Front Strut Towers
http://www.moddedmustangs.com/forums/99-04/155074-how-install-torque-box-reinforcements.html
How To: Choose a new tire
EXTERIOR / STYLING
How To: Seafoam
How To: Install hood-pins '99~'04
How To: Install cling-style tail light tint
INTERIOR / STYLING
http://www.moddedmustangs.com/forums/99-04/168046-how-install-raptor-shiftlight.html
How To: Repair lumbar support
How To: Install keyless ignition start button
How To: Paint interior trim pieces
MISC. STUFF
Test function on trip reset button
How To: 1/4 mile drag race tips
mm's nitrous mod
4.6 modular spark plug list
MOTORCRAFT
PART# / HEAT RANGE
AWSF-32C / stock heat range - copper plug
AWSF-22C / 1 Heat range colder - copper plug
AWSFA-12C / 2 Heat ranges cooler - copper plug
AGSF-32C/ Recommended for FRPP heads(not sure on heat range)
NGK
PART# / HEAT RANGE
TR-55/ 3951/ Stock Heat Range
TR-6/ 4177/ 1 Step Colder
BP7EFS (PN - 3526) BR7EF (PN - 3346) two steps
R5724-8 (PN - 7317) two and a half steps
R5724-9 (PN - 7891) three steps
R5724-10 (PN - 7993) four steps
AUTOLITE
PART# / HEAT RANGE
764s / Stock
103s / 1 heat range cooler
AR94 / 2 heat ranges cooler
AR93 / 3 heat ranges cooler
AR92 / 4 heat ranges cooler
CHAMPION
PART# / HEAT RANGE
304's / 1 stage colder
344's / 2 stages colder
YS-59C / -3 or -4 below stock heat range
DENSO IRIDIUM
PART# / HEAT RANGE
IT16 / stock heat
IT20 / -1 heat range
IT22 / -2 heat ranges
IT24 / -3 heat ranges
mm's nitrous mod
a previous post:
Alright we have been getting alot of questions about what to put on your car when its stock or just about stock. So here is a list of things to get that you will benifit the most from without hurting your motor.
1. Cat-back exhaust, you can't have a mustang without good sound to it
(MAC, Magnaflow, Borla, SLP, Bassani, Flowmaster)
2. Mid-pipe either h-pipe or x-pipe. If you are worried about inspection or emmissions get a catted h-pipe or x-pipe. ( MAC, BBK, Bassani but wouldn't reccommend it since it sounds like a loose convertor sometimes.
3. GEARS, definately a must if you can afford it cause the labor at most shops is 300 to install. 4.10 gears are the norm and there is not a difference between gas milage of 4.10 and 3.73 so get 4.10 if you want the most out of your car.
4. Shifter, cause 3rd gear is a pain in the butt. (pro-5.0 or steeda tri-ax)
5. Upper plenum (Accufab, C&L, Dragon, Trick Flow)
6. Throttle bodie, wouldn't go with a 75mm unless you have heads and cams cause it can actually hurt you. (Accufab, MAC, FRPP, Dragon, Trick Flow)
7. Tuner or chip, with the gears and all the modifications you can squeeze some extra power out with a tune, preferably on a dyno. (SCT, Diablo)
8. Underdrive pulleys, reduces drag on the accesories. (STEEDA, MAC)
9. If you need a clutch (Centerforce dual friction, closest to stock feeling, SPEC)
10. Springs, to lower that 4x4 ride height (Eibach, Steeda)
11. Longtube headers, a good improvement on exhaust flow over the stock but some might have problems with inspections (MAC, BBK, Hooker)
12. CAI, just get a little breath of colder air, only expect between 3-7 hp from these (JLT CAI or RAI highly recommended, Densecharger, Mac, BBK but don't recommend getting a chrome CAI cause it actually gets hotter air, and of course K&N)
Well thats all i can think of right now, with these modifications you will be started on the fast track to having a pretty fast car with a mean sound. And should be running in the 13's to high 12's depending on driving skills.
mm's nitrous mod
romeo and windsor difference's:
how to tell a difference externally:
run the vin
99 and 00 models were mostly windsors, and went into 01 as well
valve cover bolts are different, romeo's have 11 and windsors have 13/14
driver's side valve cover sticker will say windsor on windsor motor (not sure on romeo's)
differences between the 2:
windsor motors have press on cam gear, romeo cam gears were bolt on
windsor motors in gt's were 8 bolt crank
main caps are different
windsors have cam caps, romeo's have cam girdles
mm's nitrous mod
Trans Model First Second Third Fourth
4R44E-------2.47 1.47 1.00 0.75
4R55E-------2.47 1.47 1.00 0.75
4R70E-------2.84 1.55 1.00 0.70
4R75E-------2.84 1.55 1.00 0.70
4R70W------2.84 1.55 1.00 0.70
4R75W------2.84 1.55 1.00 0.70
4R100-------2.71 1.54 1.00 0.71
AODE -------2.84 1.55 1.00 0.70
AODEW------2.84 1.55 1.00 0.70
AXOD-E-----2.77 1.54 1.00 0.69
AOD--------2.40 1.47 1.00 0.67
AOD-E------2.40 1.47 1.00 0.67
A4LDE------2.47 1.47 1.00 0.75
A4LD-------2.47 1.47 1.00 0.75
E4OD-------2.71 1.54 1.00 0.71
T45:
1st: 3.37
2nd: 1.99
3rd: 1.33
4th: 1.00
5th: 0.67
tr3650
1st: 3.38
2nd: 2.00
3rd: 1.32
4th: 1.00
5th: 0.62 (used on 01-04 with 3.27:1 final drive)
mm's nitrous mod
installing lowering springs:
raise car in the air. support the car off the frame, not anywhere off the suspension
take off wheels
front:
take off brake caliper, abs sensor, sway bar
put jack under a-arm, jack till cars weight is on a arm
take 2 nuts 1 bolt off the top of strut
lower a-arm till strut comes out of wheel well and spindle is able to be moved out
pry down on a-arm and remove old spring
install isolator and new spring
reverse proceedures
rears:
its easier to do one side at a time
put jack under lower control arm mount on axle side and jack till axle is supported
loosen control arm bolts from axle side and pull bolt
lower slowly
pull old spring
install isolator on new spring and reinstall spring
revers procedure
this is the steps if i can remember right, i am at work right now, i will look over the mach once i get home to make sure i got it all.
Added 2 links to the original post (at the bottom)
1 - 8 of 8 Posts
Status
