441 - 450 of 450 Posts
Another slow GT
Spring Setup
$200 - CC plates
$270 - Sway Bars
$550 - Shocks/Struts
$240 - Springs
$1260 - TOTAL
Coil Over Setup
$200 - CC plates
No Sway Bars
$550 Shocks/Struts
$360 Coil Overs - Front
$450 Coil Overs - Rear
$1600 - TOTAL (their package)
Thats $400 more, and you will never upgrade it again. Plus you will have better handling, smoother ride and adjustable ride height.[/QUOTE]
This part confuses me in regards to the coilover setup. Why would I need to purchase new shocks/struts and front/rear coilovers if the adjustable coilovers come with shocks/struts? Were you referring to "coilovers" as simply the springs? If so, that seems a bit excessive. MM offers front and rear adjustable coilovers with springs for $450 front and $450 rear.
Priest of the Car Gods
I can't seem I figure out the answer so I'll ask.
I'm planning on dropping my cat with this kit: 3517.680 Mustang Eibach Pro-System Plus Pro-Kit Suspension Kit V8 Coupe 1994-2004 | CJ Pony Parts
I have a few Folloup questions about my suspension though. I was looking at getting cc plates, bump steer kit, and strut tower brace but I can't seem to make a decision. Any tips/thoughts?
Depends on how you drive the car. IMO, CC plates are mandatory and STBs are nothing but ballast. At this point I haven't driven a car before and after the install of a bump-steer kit, but if you're not noticing bump-steer and/or not pushing the car in the twisties, you likely don't need it (and you don't have to take anything else apart to get to it, so there's no advantage to doing it as a while-you're-in-there).
Becuase they don't come with shocks/struts. :)
Going from a fox mm tubular a arm to a sn95 forward offset mm tubular a arm on a fox,
Im running the standard offset a arms with the mm k member (3/4 of an inch forward) i want to switch to the forward offset a arms(1.5inches forward) and a longer a arm (more negative camber/more caster)
What would be the grip increase? Is there a precentage? 10% more grip? 20% more? I know theres a minute increase in weight distribution as well.
I've never seen grip quantified in the way you're looking to have it expressed.
Grip is based on the tire (and all it's related variables like temp and pressure), the surface, the forces applied (lateral/accelerative), the slip angle, and amount of weight on the tire.
Moving the tire forward and out is changing the static weight on the tire slightly, and the dynamic forces that are applied to the tire. If you can quantify all of those in their current conditions and in their new conditions, you might be able to generate some sense of how much less of a certain load there is on the tire in certain conditions, and then calculate how much more speed you can then carry to come back to the load that was previously applied.
Or, do before and after testing and compare lap times. That's really the ultimate judge of how effective the part is.
2002 Mustang Gt
Gonna start paying attention to these types of threads from now on!
Sent from my Galaxy Nexus using AutoGuide.Com Free App
Im trying to justify 350 dollar a arms, and the swaybar relocation bracket ill need to run those a arms correctly, i think im going to wait for now just because shes getting lots of changes soon and if i can these a arms im going to have to change so much other things, iam curious if anyone has seen an improvment from std offset a arms to forward offset a arms
