1 - 20 of 5065 Posts
Moderator
shes up in the air, and ready to be undressed. Got my unvented propane heater installed and Im ready for a nice cozy winter project.
Im doing this in a couple different phases
Phase one Ill be redoing the motor to get it ready to take the boost ill be tossing at it. the plan is as follows
Replace Forged I beam rods with Forged H beam Rods/ ARP hardware
Keep stock ported heads
new main bearing kit
Rebalance rotating assembly
Install whatever Turbo cams I buy
put the motor back together
Complete Transmission overhaul with new converter to match cams.
remove 373 gears install 327 gears.
Button her up and reinstall the motor.
This should complete all my motor trans work then off to the next phase
CG Fabrication forward facing twin turbo headers WITH AIR CONDITIONING retention!!
Fab up my own exhaust from the downpipe back
Precision Ball bearing Turbos " size to be determined
Tread stone TRTT series intercooler
46MM waste gates
50MM BOV'S
Boost controller
Ill take pictures as I go as far as fabbing ETC.
2slow is coming down Friday to help me get the motor and trans out so the party can begin.:)
Got the intake off, motor mounts, ps pump all pulleys/ac compressor off tonight!
QUICK REFERENCE
Engine removal page 6
Battery relocation page 7
410 gear removal 327 gear installation page 9
Removing piston Rods ETC page 10
ALT paining page 11
Stock K member drop page 12
Custom catch can page 12
Rear Suspension page 13
KMS Fuel hat page 13
T stat modification page 14
Mishimoto radiator install page 14
Glens performance Fuel tank install/ modification page15
UPR Chrome molly K member/ A arms/ Brake upgrades page 16
Short block page 17
Oil pan modification for Turbo drain
Line lock page 20
Oil filter relocation kit page 20
5.0 motor running again page 21
Windsor heads arrived Page 22
MMR Billet oil pump 23
Head Stud install page 23
Timing cover polished page 24
Head and timing install page 24
Motor Dropped back in page 24
New wheels page 28
Intake and 6061 plenum install page 29
First startup no headers page 31
Radiator relocation page 33
TIAL BOV arrived Page 36
PS reservoir relocation page 37
Mishimoto R series intercooler page 43
Custom over flow tank page 44
Cold side piping install/ plus welded bungs page 44
coolant overflow tank installed Page 45
Flex radiator hose page 45
CD delete gauge install page 45-46
AEM gauge and sensor install page 48
Custom Vacuum block install page 49
Hot side exhaust started page 50
Precision 60MM waste gate arrival page 52
Welding up some turbo exhaust page 53
Procharger F1C VS Precision 7675 page 54
LOKAR dipstick Page 55
Precision 7675 Polishing page 55
LOKAR mounting page 56
CG Fabrication hot side page 57
Turbo installed page 57
Couple turbo Videos page 60
Moderator
SUBBED!!! Can't wait to start reading the epicness that's about to unfold.
Im building and buying more then I want this time instead of building and maxing out what I have.
Its going to be a project over the winter months, I decided to break it up into 2 phases in case I change my mind on something Im not sitting here with a garage full of parts I don't want again. Also I get into a hurry every time I have to much on hand so im going to milk this since I have till spring.
Moderator
This is a project thread that will happen.
38mm wastegates are cheaper and will work just fine.
If you don't have a teksid block now would be a great time for one.
This will be the first CG twin 2v kit I've read about. I was thinking of getting one myself just so I'd be able to see my turbos when you pop the hood, but my setup works to well to make a change.
You'll need to get some high load valve springs in the 120lb range also.
I was waiting on you to offer up some info!! here are the springs im currently running
PAC 2v beehive spring, 1.650 install height, 110lbs seat, 265 open.
I am pretty happy with what I hear about CG and his work which is why I decided to go with his hot side minus the exhaust part cause he just don't make it.
The turbos, wastes gates etc will be the last thing I buy cause the motor is getting 100% done first.
What size turbos do you recommend?
Don't mean to thread jack Pate but I see you're changing from I beams to H beams. What's the advantage of H compared to I beams?
Moderator
The Forged I beams I have are rated at 750 the H beams I bought are rated at 900 or 1000!! I don't want to have a rod at its expected maximum capacity so I decided to upgrade them. My motor only has about 6000 miles on it.
Awesome! What kind of numbers are you expecting when it's all said and done?
The Little 2v That Could
So this CG Fab TT Kit mounts the snails in the engine-bay? You should put twin 62mm on it and shoot for 900whp+. What piston rings are you running currently and are you going to swap while it's torn apart.
Moderator
Discussion Starter #11
Not really sure to be honest, but more then I currently make on E-85 I would like to see on pump gas.
I would get better valve springs. You need the seat pressure in the 120's.
You will want the smallest turbo that will support the hp you want.
These are what I use.
Turbocharger, Garrett T3/60-1 with Stage III turbine wheel and 60-1 compressor wheel, journal bearin : atpturbo.com
Thanks ill look into these, im assuming they have very little lag. The main reason I have chose twins is to eliminate Lag.
im not sure about the rings yet once I get the motor out Friday ill be taking a look at what I have an seeing what needs to be replaced. My rods arrived today, so im ready to tear aprt the motor and send it off for balancing so I can begin the reassemble.
Moderator
Discussion Starter #14
What cams are you planning on running or did i miss that?
I am not sure what cams im running to be honest those are still to be determined.
Moderator
Discussion Starter #17
You people with your seasons! Lol good luck with the build! Mine has been a learning experience but rewarding as well
I need these seasons so I can relax a little in the winter LOL
Moderator
Discussion Starter #19
Well at least ill be able to beat you while you were blown. lol. Good luck with the build man. Sounds like you have a pretty solid plan to put some serious power down.
Thanks Froush it'll be a nice lengthy project but one well worth it in the end.
They always are no matter what it is. Even though i tell the wife im done..............we all know thats not true. haha. Just picked up a smaller pulley and a meth kit! ill be up there with you.
