4301 - 4320 of 5065 Posts
Moderator
Discussion Starter #4,302
Wow you weren't playing. I suppose you can do it in your sleep now though lol.
LOL Ive taken out and apart a MOD motor or two. Ive got everything ready to put back together I will be back up and Running by Saturday night Maybe Sunday cause I want to do some Camping this weekend.
What were the part numbers on the special head gaskets?
Moderator
Discussion Starter #4,305
I am not sure, Those ****ing Felpro are the ones that failed me, A tiny little spot in the Gasket i found that let go.... I dont get the gaskets till tomorrow but they are so special i am having them brought in on a CH40 LOL... You guys are a bunch of smart Asses which is why I love it here...
Moderator
Discussion Starter #4,307
Very True Eddie
You can see where the gaskets was Seeping. Top right by Water port..
Moderator
Discussion Starter #4,309
Find the 2008 numbers them look right above it youll see the discolored metal which is where it was seeping in that area. Picture dont really help.
---------- Post added at 12:18 AM ---------- Previous post was at 12:09 AM ----------
So...what was actually wrong....
---------- Post added at 11:18 PM ---------- Previous post was at 11:17 PM ----------
Ill save the debate...9790/9792 pt2
The gasket give out, But I had OEM gaskets this time not Felpros, it was the last 2 sets i ran were Felpro and never had an issue with those.Everything else looks great in the motor. the coolant only seeped into the Cylinder it never made it into the oil.
Moderator
Discussion Starter #4,310
Made some progress today got the motor back together. I Also got the engine reinstalled before the wife came out and demanded I go shopping so im giving in for the day Lol...
Moderator
Discussion Starter #4,312
About 12 rolls do you need some? ? I'll get you those parts numbers when I get back from forced shopping.
Wish I could pull my engine with headers attached.
Moderator
Discussion Starter #4,315
It's not easy As it looks it takes some manipulation and 2 sets of hands. Hardest part is earing all that AC stuff that I won't part with lol.
Moderator
Discussion Starter #4,319
More work for me to go out the bottom because then i would require an Alignment. If the K member shifts at all it throws out your Alignment so thats just more time and money to be wasted.
I should have the car running tomorrow if I can get it done by 3 cause after that im starting my Memorial weekend.
---------- Post added May 28th, 2016 at 12:32 AM ---------- Previous post was May 27th, 2016 at 10:32 PM ----------
Those gaskets had magical fairy dust on them which makes them special.. I put on 2 pairs to make it that much more magical.
