1 - 7 of 7 Posts
Yeah i know there is a lot more to it then just a parts list but just wondering if i am in the ball park out here. Still waiting on the tuner but guessing mid to upper 400s. I would be very happy with mid to low 11s giving it is a street coupe around 2900 lbs ????
DSS super pro bullet 331
Vortech S trim supercharger
Forged crank
4340 H beam rods
Arp rod bolts
DSS pro x forged pistons running 9 to 1 CR
Performer rpm heads 2.02 1.60 valves
Anderson b41 hr blower cam
4130 pushrods
Arp perma-lock rocker arm adjusters
1.6 roller rockers
Polished cobra intake
Cobra valve covers
Performance automatic super comp c4-
Trans with trans break 1000 hp rated with a lifetime warranty
Pro torque converters 4600 stall
3.73 rear gear stock LSD :eek:
275 DR's Nitto's
Well should be around 450-480 ish. I am sure there is more there but want to try to keep this block around for a season or two. you think she can make 10s with the stock rear on DR's :eek:
BYAHHHH!
or run a T trim.
Gonna need better tires than Nitto's
I dropped my rear when my axle broke with less than 300rwhp good luck with that stock rear. Or did u get the new 28 spline mosers?
not only is the stock rear not legal for 10's, the first time you come off the trans brake with your combo you'll be putting a rear in it (if the 275's hold at all)
I'd upgrade the rear before I even went to the track & get some better tires.
1 - 7 of 7 Posts
