Hi everyone, I have a 2000 Ford Mustang. Right once you turn the ignition on the third brake light lights up barely and will always stay on. When you turn the headlights on the brake lights are always on. I’ve checked the bulbs, brake light switch, headlight switch, pulled fuses and the only fuse that made it go off was #41 and it’s for the brake lamp. This all started when I connected the battery again after a motor swap. Also the battery was disconnected for 8 months. During the motor swap the only wiring I touched was in the engine bay. What could this possibly be?
