1 - 4 of 4 Posts
Hi
I have a heavily modified 2006 Saleen S197 which I took to the dyno several weeks ago. The car was running fine when I dropped it off.
Got a call to say there was an issue and was in limp mode
Unfortunately here in Australia there are not many S197's
Took the car home and it will only start with the throttle body disconnected and run in the limp mode
Tried reinstalling previous tune but to no avail.
With the throttle body connected it is making a chattering sound and won't turn over
It is showing these codes P2107 and P2110
Cannot clear these codes with my SCT tuner. Have 3.87 volts at each pin
Have put a new complete Ford throttle body on.....same issue
Changed throttle pedal assy
Have changed numerous parts off one of my other S197's still same problem
Checked all fuses and relays plus earths....still nothing
The dash is showing "check charging system" and "DTE Data Error"
Running out of options any ideas or help would be appreciated
Hey if you google your codes and the DTE Data Error there are lots of threads on other forums that may help you find a solution. I would say take to Ford but they will blame everything on your mods. Any good performance shops in you area?
Hi
After 3 months of trying to find the problem including 2 tune guys and swapping out sensors, fuses, relays and numerous other parts. Finally found the issue last week, turns out I had a bad fuse box. Swapped it out with another box and solved the problem. I am going to seperate the two halves and see if I can see the issue
Thanks for your input
1 - 4 of 4 Posts
