1 - 4 of 4 Posts
Hey anybody, I am throwing the P2104 & P2111 code with my Ford GT500 t/b. Before I trying taking it apart. I had a stupid question. When I maually open the throttle body, should it stay open of close on it's own? I always thought it should kind of snap shut when you let go but i have to manually close mine. Thanks for any help...
hmmm i believe it should just shut on its own, spring loaded isnt it?
I replaced mine with the FRPP unit and it closes shut immediately after you let go of the blades. The "P2111 - Throttle Actuator Control System - Stuck Open" code will cause the car to throw the "P2104 Throttle Actuator Control System - Forced Idle". I had these same exact codes on my 2006 Explorer and it turned out to be the TPS sensor was gone. But in this case it seems to be mechanical if the blades are not shutting on their own.
1 - 4 of 4 Posts
