So I am about to be on my 3rd throw out bearing and I am getting tired of replacing them so quickly!
So a little background here...I have a 98GT that has Griggs K-Member (don't know if that would matter but never know), she started out as an Automatic but since I had a donor 98GT I swapped it to a 5speed. All of the parts were direct swap from another 98. Pedals, drive shaft, mounts and everything. In addition to that I added a Spec aluminum flywheel, UPR firewall adjuster, UPR quadrant, OEM Ford cable, and Spec clutch kit. After 800 miles the throw out bearing started making noise. I assumed it was because I used the Spec TOB. So I dropped the transmission again and replaced the Friction plate on the flywheel, install a Center Force Clutch kit with Ford Racing Throw out bearing and pilot bearing, Ford Racing clutch fork, Ford Racing clutch fork stub, billet steel throw out bearing sleeve (the one on the transmission), and installed the Steeda clutch quadrant since it had more adjustments. I hoped with all of that I would eliminate whatever the issue was.
I read a lot about clutch adjustments and where you want to have it. A lot of people generally say you do not want the throw out bearing to have any preload on the pressure plate. But if I did not adjust the clutch to were the throw out was touching the pressure plate I could not get the clutch to disengage. I also installed a spring kit on the clutch cable to help move the TOB away from the pressure plate but that did not help. I could still never adjust it to where it was not touching which I am assuming is the reason the throw out bearing go out so quickly...I am about to just buy the McLeod hydraulic clutch kit and hope that fixes it but I would rather not if I have the option.
I know several people have had this kind of issue before but I can never find the solution for it...idea's?
