So I bought a new edge for a pretty good deal from a co worker. It’s had a lot done like a new jasper motor, Detroit rear end, built tranny, short throw shifter etc. just basic stuff. When I started the car for the first time there was a ticking noise. I was told it was because it was sitting and the lifters probably just needed to be pumped up
so I drove it home. Still ticking. Changed the oil, still ticking. It’s a very odd tick. The ticking is all the time. At low rpm through high rpm. I’ve pulled valve covers off and everything looks good. Motor probably doesn’t even have 1500 miles on it. Checked for blown spark plugs nothing. It isn’t injectors because it’s a very slow tick, but increases with rpm. Bottom end sounds good. I’ve checked exhaust manifolds to see if they have cracked but nothing is indicating a leak. I mean the car runs like a bat outta hell but the ticking noise is terrible. If I could get some kind of help it would be much appreciated, thank you !
