1 - 5 of 5 Posts
hey guys, so my inner tie rod ends seem to be pretty worn and i figured i would tighten up the front suspension a bit while im in there. so im here to ask you to help me complete my checklist before i head to the parts store.
-inner tie rod ends
-outer tie rod ends
-sway bar endlinks (hoping to find shorter than OEM cause im lowered a bit)
-sway bar bushings
-possibly control arm bushings.
anything else i should consider to tighten up my front a bit then ill get an alignment?
It's not technically suspension but a steering rack that eliminates the rag joints would make the car feel tighter.
Correct!
A set of aluminum rack relocating bushings would help in aligning the tie rods to the lower control arms. This will give the car a more go-karty feel!!
John
what do you mean rack re-locating bushings? got a link??. i know where to get aluminum rack bushings but not sure what ones your talking about
1 - 5 of 5 Posts
