1 - 5 of 5 Posts
What timing covers work with an 05 mountaineer aluminum block?
Anything else I would need that is specific to that year block?
To me it seems as tho the block should be the same as my 98 block, just aluminum, yea?
99-04 mustang will work. You just have to fill one of the holes with silicone.. I have several if u need one..
Okay sweet, have you done this and does it seal up well? Couldnt I drill a hole in the timing cover to also fill it, or is the hole on the block in a bad spot in the timing cover?
How much are you wanting to give one of those away for?
If Ur using Ur heads and valve covers then you're cover should work jus fine.. and yes I done this swap. It didn't have any leaks..
Alright sweet man, thanks. I am doing some pi heads and all that good stuff.
Are you happy with how it turned out? Did you weigh your car before and after?
1 - 5 of 5 Posts
