Can I install new camshafts in the same exact positions as the stock ones pictured and be ok ?
Crankshaft locked, chains secured on the crank gears so they won't slip. Mark where the gear lines up on the chain as it sits (in pics). Going one side at a time installing the new camshaft in the same position as the stock ones are in . This is an easy option for me if it will work.
Thanks for your thoughts.
