is there any way to adjust the timing with out a tuner?
then i suggest you dont advance your timing. any other way is potentially harmful to the engine.i don't want to buy one
and if it pings/detonate rip it apart and star again? sounds like a PITA not to mention how would u know how much you have adjusted it?actually YES there is
you can advance the timing on your cam or retard it
so the answer is YES it is possible to ADJUST timing without a tuner
He said it was possible, not smart.and if it pings/detonate rip it apart and star again? sounds like a PITA not to mention how would u know how much you have adjusted it?
well first off its MUCH MUCH MUCH more common then using a tuner. infact any v8 motor you buy you will have that optionand if it pings/detonate rip it apart and star again? sounds like a PITA not to mention how would u know how much you have adjusted it?
actually with a cam its the ONLY ideaagreed it dont sound like a good idea
im not saying ur idea is ridiculous im saying its not a very safe way for a person to do it unless he has experience in the subject which buy the OP its clear he does not. its also not as simple as a tuner like we all agree.well first off its MUCH MUCH MUCH more common then using a tuner. infact any v8 motor you buy you will have that option
any engine you rebuild you have to adjust timing!
its VERY easy if you know what to do and VERY easy not to screw up
and ask any carb setup guy how he adjust his timing. aside from saying his distributor he'll say a cam. you say well why not a tuner...him-->umm what?
yes i know we're not carb'd but your making it seem like my idea is rediculous and its more benifical then a tuner
and REQUIRED with any CAM Install
and there is are timing marks and about scale that reads -10 to 0 to +10
its as easy as turning a wrench
dude obviously if your changing your cam you set up accordingly, Like i said before he just wants to adjust the timing. as far as we all know there isnt a cam swap. like i said for his situation a tuner is a good idea the other methods are not practicle for him and or dangerous to his motor.actually with a cam its the ONLY idea
but i guess we could just throw in a cam and only adjust timing with the tuner! that'll work super great?
hmm looks like false information a little in my eyes
too bad you probably couldnt do thatguess i should have adjusted my cam for my +3 degrees of timing on my stock cam rather then using my tuner![]()
no post was edited. OMZ was the first to say yes it was possible. No your not getting to me. not every one is such the pro at cam tuning like torres is so like i stated before tuner is his best option. unless he has the know how for the other 2 methods and wants to do it. NO i wouldnt know adjust timing via cam but if i looked into it who are you to say i couldnt?well in that case putting a tuner in someones hands that doesnt know what -6 spark means or +9 they might say oh hey 9hp!
hmm i can put this many way
i think adjusting a cam is pie
so is playing with a tuner
but the question was if there was a way to do it without and tuner none the less the question wasnt answered correctly and im pretty sure you went back in edited your post too
awww is itschristorres8 being right about a tranny thread getting to you now:no
