1 - 8 of 8 Posts
Hey guys, I have just the stock tires. 275 \55R16 I live in Pensacola Florida, so it's hot, and humid. My tires are at 32 PSI atm, but I read the tire and it says max 44 PSI, What's a good tire pressure?
Not A Regular Member
Hey, sorry I didn't notice this earlier but I was talking to 6er on FB and he mentioned it. I was going to recommend 38psi but 6er says 35psi is right where you want to be.
Also from 6er, "let greg know the reason i say that is because he said it's humid...remember for every 10 degree change in temp a tire gains or looses 1psi"
the max psi is what the tire load range will hold but not necessarily what u should run. for example a 10 ply load range E truck tire max psi is 80 psi. some ppl run max psi cuz they are hauling extra weight like a trailer and some ppl dont run that much because they dont have extra weight and it will stiffen the ride with more pressure. like mcqueen said 35psi is fine.
1 - 8 of 8 Posts
