1 - 20 of 21 Posts
whats the biggest tire i can get on the front of my car,its been lowered by cuttin 1 1/2 coil on each side an the back is stock without the insulators,i got a set of sumitomos 255/45/17 for the back,will they fit the front without rubbing?
so 255 on the front will be ok?by the way i have stock 17 wheels.it has 255/40s now but i think the 45's will get it off the ground a little
Resident Bubblehead
255's will fit fine up front. i have 255's in front and 275's in back, soon to be going to 315's in back. i think 275 is the biggest you can go up front without having any rubbing issues...
Resident Bubblehead
i think you can fit a 275 on an 8 inch rim, but i wouldn't go any bigger. they fit 9's great...
zippeewannabee
i have the cobra rims.. will the 315s fit that?
Resident Bubblehead
i think Cobra rims are 9's. 315's are too big for 9" rims...
275 is the biggest for an 8 inch wheel.
305 is the biggest for a 9 inch wheel.
depending on tire brand, 315 is the biggest for a 10 inch wheel
up to a 325, again depending on tire size on a 10.5 inch wheel
it's not really brand dependent, but how tall the side wall is. A taller side wall will allow you to fit a slightly wider tire on the same size rim.
for instance...nittos run narrow while bfg tend to be wide...contact patch that is
and i agree with the sidewall
true, I forgot about that. I was assuming they were all the exact same measurement.
ill prob go with 255 front an 2 75 back,will the 275 rub in the back
no, you can go 315 out back without rub as long as you're not sittin' on the ground
1 - 20 of 21 Posts
