What is the widest tire you can put on, 18X9 and 18X10 rims
0 07gtmustang · Registered Joined May 23, 2007 · 555 Posts Discussion Starter • #1 • Feb 24, 2008 What is the widest tire you can put on, 18X9 and 18X10 rims
0 07gtmustang · Registered Joined May 23, 2007 · 555 Posts Discussion Starter • #3 • Feb 24, 2008 they recomend 275 for the 10 inch do you think 305 would be pushing it too much
HMUSN · Doc Joined Nov 6, 2006 · 37,101 Posts #4 • Feb 24, 2008 i wouldn't do a 275 .. that's a bit small honestly.. who rec's that? it should be at least a 285. anywhere from 285-305 will fit.. some 315's will as well but it's brand specific.
leebunnyz · Registered Joined Feb 2, 2007 · 3,580 Posts #5 • Feb 24, 2008 i have 305's on my 18x10...315's are the widest you can go though.
Jucostud · booooost'd Joined Nov 19, 2006 · 7,545 Posts #6 • Feb 24, 2008 275 is perfect for 18x9, way too small for an 18x10.
0 07gtmustang · Registered Joined May 23, 2007 · 555 Posts Discussion Starter • #7 • Feb 24, 2008 oh ok on american muscle that is what they recomended so I wanted to check, so your saying 275 on a 9in for the fronts won't rub?
Jucostud · booooost'd Joined Nov 19, 2006 · 7,545 Posts #8 • Feb 24, 2008 no, it won't rub. 275 is the max you can have on the front without rubbing.
