1 - 5 of 5 Posts
What is the fattest tire I can put on a 17x9 Cobra wheel? It seems that 275/40 is the most common, but is there anything bigger that will fit and look good?
the shoulder of the tire will roll with a 275, it's what I have on mine, but would like to go to a 315, with different rims of course, 10.5
03/04 guys put the 315 nitto's on all the time,a nd they hardly buldge, the 315DR's are very under sized.
for the front though, stick with 275's.
62mm TiT's
go to the manufacturer that makes the tire to see what the width is of each tire you are interested in...it will tell you what the reccommended wheel size is and what you could get away with...
you can fit nitto drag radials on the stock 9" wide rims. the nittos are narrower than others so it allows them to fit:yes
1 - 5 of 5 Posts
