1 - 20 of 31 Posts
New wheel and tires from AM, rears are mounted correctly tread arrow going the right direction. However front the tread arrow seems to be wrong for the direction of travel and the the actual tread pattern is in the opposite direction from the rears.
Please confirm AM messed up before i start calling peoples. THX guys!
First Image:
Bottom of this image is the front passenger side of the car
Second image:
Take from the front of the car looking back at the passenger front tire.
BTM AutoSport
switch the left and right tires up front if they are both backwards, your problem should be solved.
No longer Maching out...
Abyssinian of AX
I was trying to imagine in my mind if swapping from one side to another would solve the issue or not. Mental block im not convinced lol ill draw it out.
BTM AutoSport
or you could just go jack the car up and swap the wheels around and say, damn, that iRoush guy was right and also sexy.
That will solve the problem as long as your other tire is the wrong way as well.
That's what you get for ordering crappy Sumitomo tires! ;)
Hahaha, iRoush is right. You mounted the wheels on the wrong side of the car.
Send them back to AM and demand they swap them... :shiftyeyes
Discussion Starter #12
Thx gentleman, for the light ribbing as i deserved much worse. lol Tires have been swapped and all is well.
Anandavenkatakrishnan
Did you say iRoush had a sexy car too?
Admanistrator
:lol
Oh, as long as you have your car jacked up, you should probably check your blinker fluid level. It's always smart to make sure you're topped off going into the cold months.
Mr. Stangarang
:facepalm:
Abyssinian of AX
anybody else notice how hot that Roush dood is?.. DAMN!
1 - 20 of 31 Posts
