255-60-15What size are the slicks?
I am going to try to run a MT ET Street on the back of my 88 LX. Will a 255-60-15 fit with no probs. This will be on a stock 10 hole wheel. Thanks for any help.
the only way to get a 275 to fit on a fox is to remove that spring in the back of your car
i cant remember what its called but i know without moving that spring the bigest you can fit is a 255
I thought that it was a 27 in tire. I am stock geared now but am going to go with a 3.73 next month. I am not expecting any times right now. I just got the car and am going to go out and run a couple times to get the feel for it. I have the 7 inch stock wheel and was just looking for something that was going to hook up. I was going to go with a 235 (which I thought was a 26 incher)but wasnt sure if that was just a waste of money or not.So....anyway....you realize that the 255/60 is a 28 inch tall tire, right?
it'll probably fit on an LX, but that is likely a taller tire than you need. What gear ratio are you running and what times are you expecting?
Since when is a 255/60/15 a 28" tall tire? A 275/60/15 is a 28" tall tire... the 255mm tire with a 60a/s is 27".So....anyway....you realize that the 255/60 is a 28 inch tall tire, right?
The 255mm tire will fit no problem. The 235mm would definately suit your needs alot better with your stock gearing, because its an inch shorter than the 255mm (assuming both have a 60% aspect ratio). The trick to selecting tires is to run the smallest you can hook with. A 235mm should be plenty.I thought that it was a 27 in tire. I am stock geared now but am going to go with a 3.73 next month. I am not expecting any times right now. I just got the car and am going to go out and run a couple times to get the feel for it. I have the 7 inch stock wheel and was just looking for something that was going to hook up. I was going to go with a 235 (which I thought was a 26 incher)but wasnt sure if that was just a waste of money or not.
