Your Ford Mustang's performance is only as good as the tires it sits on. If you can't imagine your life without high speeds on the highway or on the race track, consider getting a new set of performance tires. Unlike regular tires, they are built for speed, excellent traction, and cornering. They have unique tread patterns, construction features, and rubber compounds to provide enhanced precision, responsiveness, and traction to maintain a maximum grip on dry surfaces.
Below you will find our list of the best performance tires currently available at CARiD.
#1 Michelin PS4S
www.carid.com
Features:
#2 Nitto NT05R
www.carid.com
Features:
#3 Toyo R888
www.carid.com
Features:
#1 Michelin PS4S
MICHELIN® - PILOT SPORT 4 S ZP (RUN FLAT)
PILOT SPORT 4 S ZP (RUN FLAT) Summer, Performance, Track / Competition, Run Flat Tires by MICHELIN®. This tire is available in various sizes. Choose the desired width, height and radius from the option list.
Features:
- Dynamic Response technology for enhanced handling, steering and longevity
- Multi-compound construction for superior wet and dry performance
- Designed to deliver both incredible traction and improved tread life
- Deep rim protector to guard against light wheel damage
#2 Nitto NT05R
NITTO® - NT05R DRAG RADIAL
NT05R DRAG RADIAL Summer, Performance, Track / Competition Tires by Nitto®. This tire is available in various sizes. Choose the desired width, height and radius from the option list.
Features:
- Competition Performance - The large solid center rib provides a continuous contact patch for excellent dry traction
- High-Speed Stability - The enhanced sidewall construction, high-modulus bead filler and large shoulder blocks increase straight-line stability
- Specialized Race Compound - The new drag racing-specific compound is engineered for increased traction at the starting line
#3 Toyo R888
TOYO® - PROXES R888
PROXES R888 Summer, Performance, Track / Competition Tires by Toyo®. This tire is available in various sizes. Choose the desired width, height and radius from the option list.
Features:
- Unidirectional V-shaped tread design
- Enhanced R-compound tread
- Stiff bead construction and wider tread width
- Continuous center contact
