Anybody running a tork tech GT kit with Trickflow heads? I have a TT kit and am contemplating ported PI or trickflows.
Obviously it is not ideal if you want to maximize your setup. If you are on the stock bottom end, a set of N/A cams will help keep cylinder pressures down (leak some boost) which is helpful on stock rods and pistons. I'm personally running N/A cams on my boost stock bottom end car with no worries whatsoever.So a I have a set of comp xe262ah stage 1 cams for my NA motor. Will these perform ok with the tork tech eaton setup with their 113 lobe separation or should I definately go blower cams? Trying to decide if going to blower cams is really going to net gains worth of selling these cams and spending more $$?
