I have searched the forums here for a thread on torque specs, found one from silverstang and saved it. my question is where can i go to find specific specs? i need everything in lb-ft. mainly looking for panhard bar, anything suspension related really since that is my current project.
I saved this...can't recall where I got it...but it is a word doc on my laptop. Thanks to whoever compiled it.
Mustang Torques:
Torque specs for front Suspension
(Nm = Newton Meters ft/lbs = Foot Pounds in/lbs. = Inch pounds)
Brake Caliper Bracket Bolts: 133 Nm - 98 ft/lbs.
Dust Shield Bolts: 20 Nm - 15 ft/lbs.
Wheel Spindle Pinch Nut: 103 Nm - 76 ft/lbs.
Lower Control Arm Bolt (front): 175 Nm - 129 ft/lbs.
Lower Control Arm Bolt (Rear): 175 Nm - 129 ft/lbs.
Heat Shield Bolts: 10 Nm - 89 in/lbs.
Brake Line Bracket Bolt: 20 Nm - 15 ft/lbs.
Strut Upper Mount: 62 Nm - 46 ft/lbs.
Strut to Spindle Bolts: 200 Nm - 148 ft/lbs.
Strut to Body Nuts: 35 Nm - 26 ft/lbs.
Wheel Hub Retainer Nut: 300 Nm - 221 ft/lbs.
Stabilizer Bar Bracket Nuts: 70 Nm - 52 ft/lbs.
Anti-lock Brake Sensor Bolt: 6 Nm - 53 in/lbs.
Outer Tie-Rod Ends: 80 Nm - 59 ft/lbs.
Steering Gear Mounting Bolts: 115 Nm - 85 ft/lbs.
Torque Specs for Rear Suspension
(Nm = Newton meters ft/lbs. = Foot Pounds in/lbs. = Inch Pounds)
Rear Shock Absorber Upper Nut: 40 Nm - 10 ft/lbs.
Rear Shock Absorber Lower Bolt: 115 Nm - 85 ft/lbs.
Lower Arm to Body Bolt: 175 Nm - 129 ft/lbs.
Lower Arm to Axle Bolt: 175 Nm - 129 ft/lbs.
Panhard Rod to Body Mount Bolt: 175 Nm - 129 ft/lbs.
Pahhard Rod to Axle Bolt: 175 Nm - 129 ft/lbs.
Lateral Stiffener Bar to Body Nut: 115 Nm - 85 ft/lbs.
Lateral Stiffener Bar to Body Bolts: 62 Nm - 46 ft/lbs.
Stabilzer Bar Bracket Nuts: 70 Nm - 52 ft/lbs.
Stabilizer Bar Link bolts: 115 Nm - 85 ft/lbs.
Parking Brake Cable Bracket to Lower Arm: 27 Nm - 20 ft/lbs.
Upper Control Arm Front Bolt: 175 Nm - 129 ft/lbs.
Upper Control Arm Rear Bolts: 115 Nm - 85 ft/lbs.
Upper Control arm Bushing Nut: 175 Nm - 129 ft/lbs.
Fuel Tank Strap Bolt: 51 Nm -38 ft/lbs.
Brake House Bracket Bolt: 20 Nm - 15 ft/lbs
