1 - 15 of 15 Posts
I just bought a new tps sensor and just like the old one I can't get it to read anything. What could be the problem???
Are you back probing the right wires?
green and black
green and black
Those are the right wires, do you have the engine running when you check for a reading? If so try and check voltage where the TPS connects to the harness.
key on engine off no accesories on either
I'll try that tomorrow.
Discussion Starter #9
Still does not read.
maybe your vref is shot - checck the red wires at the MAP/BAP and EGR position sensor. If the 5vdc is not there, the vref is blown or a wire has been disconnected.
what do you mean vref blown? I am having a similar problem. The vref has declined in the last vouple of days. The BARO sensor is geting the the vref. It has now hit .10 v
My connections should be good. I suppose I could give them all a good dab of dielectric grease but I have a feeling that will not help. It seems like my computer is not working properly. I had the harness out and checked continuity of all the TPS wires and got 0 ohms on all of them I will check tommow with the harness in the car from sensor plug-in to ECU plug-in. I have checked every thing I can and so far it all points to the ECU. The only other thing I can think of is my relocated battery cable might be causing interfearence in the computer area as it might be too close. I did try to sheild it though.
The computer gets 12v from the battery, the computer takes that 12v and makes 5v for VREF - if that circuit that does the voltage reduction is bad, then it's "blown" - as in smoked, as in fubar, as in history..............
1 - 15 of 15 Posts
