TPS
977 Views 4 Replies 4 Participants Last post by  castine917
On my 95 i checked the voltage on tps with it closed it had 1 volt and at wot it had 5 volts is that right or bad tps lmk thanks
1 - 5 of 5 Posts
@ idle you should have around .96-1. so it sounds like its fine
Your TPS is within spec.
Thnaks
as you increase throttle smoothly the voltage should increase smoothly also. if voltage jumps drastic it would indicate a bad t.p.s.
1 - 5 of 5 Posts
