Well i was informed that the B-heads for my 96 cobra engine swap will not match up to the Eaton M112 S/C. So now im in a bit of a pickle... Anybody have any suggestions>?<
You will most likely have to modify the intake flanges on the navi heads to make the manifold fit. Its for a 5.4 so the gap in between the heads is smaller when you put em on a 4.6. From experience on the navi heads on a 4.6 there will be some modifying to do.Ok so i talked to a guy and he has a set of 00 navi 4v heads. Are those c heads and will they match up with the eaton S/C from an 03 termi engine?
