1 - 9 of 9 Posts
ok so here's the deal with my tranny...
i'm having a whole lot of problems with it
3rd gear grinds very rarely and its usually only when it is cold, but i haven't had too much of a problem with it, usually only happens when i shift really low, maybe 1.8k...but it wails like a banshee!!! and gets louder and louder as the revs climb
2nd whines too...not as much but it does
i think 5th does it too(tends to grind a lot),
also, i can hear like something is loose and rattling...when i put it in neutral i can hear it too,
if i have the clutch in after putting it neutral from any other gear i can't hear it. but the moment i take out the clutch i hear like this rattling noise...
so basically i'm saving up for a rebuild using parts from promotion, haven't called them yet...but i know i'm going to need the carbon fiber synchro kit, but what else? would you recommend the billet shift forks as well?
i'm not looking to make a whole lot of power, probably do some suspension work after i get the tranny in, then 3.73, then a 100 shot
mm's nitrous mod
their reman comes with carbon fiber sync's, and a later model 3/4 fork. it is plenty capable of holding a bolt on car. they will advise an input shaft upgrade, but the building process of their trans is totally up to you. i have one and love the hell out of it.
Discussion Starter · #3 · (Edited)
i'm kind of tight on $$$ so i was thinking of just getting the parts i need and having a local shop rebuild it with the parts from promotion
hoping to keep it under $1300 including labor...not sure if this is possible...
you having a shop pull and reinstall the trans or just build the trans?
probably just rebuild my tranny using the promotion parts...install as well
what do you recommend?
link to promotion parts?
apparently they don't answer emails...lol
i'll probably give them a call soon, don't have the money yet and the transmission hasn't completely given out yet...but maybe they can give me a quote so i know what to aim for
1 - 9 of 9 Posts
