1 - 1 of 1 Posts
I smell like beef
I'm installing a trans cooler on the return line off the radiator. The lines on my '04 are steel all the way to the tranny and not rubber in sections like on every trans cooler install page on the web. To run this in sequence, do I need to just cut a section out of the return line, flare the ends, and then connect the trans cooler. The cooler came with an instadapt but you still have the fitting attached to the original return line.
I just wanted some opinions before I cut my lines.
1 - 1 of 1 Posts
