1 - 8 of 8 Posts
Are you guys using one of the test ports on the trans to run the trans temp sensor? Do they make a pan that has a bung for it? Also where are you guys routing the wires up into the car?
Thanks
Super Moderator
I essentially welded a bung and ran the TEMP sensor in the pan.
Super Moderator
wouldnt it fit in the tetst port?
I dont see why it wouldn't but for me i want to see what the fluid temperature is of the fluid getting pumped into my transmission from the pan. This should give you an ideal what the average temperature of the fluid is between what is returning to the pan and what is getting sucked back into it.
Super Moderator
I would be curious to use the pan and a test port both but only plug one sensor up at a time to see how far off the reading will be. I would bet they would about be not enough to matter.
1 - 8 of 8 Posts
