1 - 4 of 4 Posts
i have a 89 4 cyl. and the a4ld trans. broke
i put a v8 gt tranny in with bellhousing on the 4 cyl.
when i have the stang up off the ground in the rear it will drive threw the gears but when its on the ground it will not go anywere
does this tranny work with a 4cyl.?
could it be a tail shaft broke?
any suggestions?
also i did put a new filter/screen in it and has new fluid
no shavings or trash was in the tranny
Perhaps it could be your clutch? I would consider adjusting the cable tighter and see if you have any luck.
Firewall adjusters are nice too and come in handy to help get the clutch set up just how ya want it.
The valve body is more then likely trashed. Either that or the pump is. It sounds like it is not getting the pressure it needs to lock the clutches when its under strain. Is your TV cable adjusted right?
1 - 4 of 4 Posts
