1 - 18 of 18 Posts
okay, I am not one for the transmissions, but what does the 99 3.8 have? is it the 4r70w?[SIZE=-1][/SIZE]
MM's official Chevy guy
ya if it is a auto.
ya
why
I was researching my transmission and what I could do to make it stronger, and I didn't know that these two cars had the same one.
ok, well there isent much u can do to make the auto stronger other then building it, wich can be a bit of a time consuming pita.
j-mod valve body
and changing the fluid every 40k miles
if you've waited to long like 80k with out changing it...i probably wouldnt change it
j-mod valve body
ya those r good things to do, that will make it a better trany, but they won't realy make it any strong (ie. able to andle more power)
not trying to be a hard as chris just want to clarify this.
car only has 37k on it. haha. i have a donor car with a 4.6 im thinking about mounting, but i dont want to pull that trans and mount it if i dont have to, if mine will fit...
u will need to swap the bell housing
Number one
i simple j-mod will allow i to handle a little more
secondly
Everyone has this huge fear of cracking an automatic open
its not as big of a deal as its made to be
Number one
secondly
i will agry if u r talking j mod/shift kit wize
but rebuilding is a whole nother stroy, it isent much harder then a manual but even rebuilding those is a pita.
¡ʇsnq ɹo uʍop ǝpısdn
The bell housing and input shafts are different and the electrical hook ups might be off too
1 - 18 of 18 Posts
