1 - 15 of 15 Posts
Alright, so I painted my throttle body as planned, came out ALRIGHT but definitely not a pro job.
Now my problem is, I started the car without the wire for the mass air plugged in, and without the tube from the intake to the IAC plugged all the way in and it was really messed up, then I realized what I did and fixed it, but now I'm throwing code P1120
SOMEONE HELP PLEASE! It's idling at about 1250 and fluctuating between normal idle and that. I tried slightly adjusting the throttle screw thinking maybe some paint got on it and threw it off, but it didn't change anything..
Did you try unplugging the battery for 10 minutes or so and giving it another try?
No, do you think that would work? I tried clearing the code with the tuner if that's anything like unplugging the battery
Yes, it's different - unplugging for long enough SHOULD reset the fuel and spark tables on most cars back to factory.
Alright, I went out an unplugged the negative about an hour ago...Like I said, i'll plug it back in, and start her up tomorrow morning and see what happens. Hopefully you're right and I'll save myself the trouble of a new sensor or whatever it would take to fix it.
Discussion Starter #9
Should I try taking the one off my stock TB and see what happens or would I be wasting my time?
Did you damage the tps wire(s) at all in the removal of the plenum?
That code is caused by low voltage. I would check fir signs if damage to the wires first. Did you allow any moisture to get into the sensor while it was apart?
Worse case scenario I would go get another tps sensor (about $40) and install it.
Discussion Starter #11
Actually its a very good possibility that some moisture got into the sensor. Should I try taking it apart and blow drying it or is it already shorted or done?
You could try that, doesn't hurt. But chances are you'll end up needing to replace it. Luckily it's one of the cheaper sensors to have a problem with.
Discussion Starter #13
Yeah, but again, I could take the one off my stocker and try that, no? and there wouldn't be damage to any lines past the sensor if there was moisture in it, right?
1 - 15 of 15 Posts
