1 - 5 of 5 Posts
Last night I had trouble putting my top back up for the first time in her 65k. I am pretty handy with a wrench but have no idea where to start when it comes to convertibles. The motor engages but I had to help it up manually. I want to avoid paying out the wazoo and fix this myself. Any help would be greatly appreciated as I am new to this site.
Check the motor, flush it (the pump), make sure there's no air bubbles in the system. If that doesn't work, then it's possibly time for a new motor.
~C~, The Other White Meat!
I am willing to bet that unless you have a leak in the system (in which you would probably see some fluid outside) that there is no problem with air. I bet the motor is going. Mine is working fine, but over the course of 10 years, I found the motor to not be as strong as it used to be. I think it depends on how much it is being or has been used.
But, like Leftorium said, may as well check the ****.
1 - 5 of 5 Posts
